1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Setting States for an MBBI Record
To: [email protected]
Date: Thu, 30 Jul 1998 12:35:03 -0700 (MST)
Hi tech-talk,
I am having trouble getting an MBBI record to handle the values
I set in the ZRVL, ONVL, TWVL, ..., FFVL fields. I am new to EPICS
so maybe the error is in my understanding, but here goes...
I have built a database which contains an mbbi record that receives
its input from an analog input record which in turn receives its
input from a hardware input addressed to an address on a PLC.
The PLC address is for a 16 bit word which will at most have only
one bit on. Thus the values for the word (in decimal) would be:
0 (no bits on), 1, 2, 4, 8, 16, 32, 64, 128, ..., 16384, 32768.
I set up the ZRVL thru FFVL fields to correspond to these numbers and
set the corresponding strings ZRST thru FFST to be the string
descriptions for the 16 states.
For the first three values (0, 1, 2) the behaviour is as expected -
the ZRST, ONST and TWST strings as displayed. But inputting a 3
(where THVL=4) displays the THST! Inputting a 4 displays the FRST
and on and on all the way up to 15. Entering a value larger than 15,
e.g. the value 16384 which is assigned to FTVL, leads to the string
"INVALID VALUE" being displayed.
Looking at the properties for the mbbi record loaded on the mv167,
I can see "SDEF" = 1, but the behaviour is as if none of the
states have been defined and that they have been assigned the values
0 thru 15 for me.
Dayle Kotturi        [email protected]      Gemini 8-m Telescopes Project
Software Engineer    1-808-933-7165 (v)    180 Kinoole St. Suite 207
                     1-808-933-7123 (f)    Hilo, HI  96720
Prev: EPICS and PPC Andy Foster
Next: Re: Setting States for an MBBI Record Ned Arnold
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
