1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: MBBI, SHFT, and GDCT
To: [email protected]
Date: Mon, 17 Aug 1998 12:22:27 -0500
re...
> > > But if SHFT were allowed to be set by GDCT, wouldn't it just be
> > > overwritten by the device support layer in the cases where the device
> > > support sets this field, thus making it work for all cases?
> > Yup. I neither see any problems with the SHFT value made DCT accessible.
> > What do you think, Marty?
> I dont see a problem except that it may be confusing.
> > Another workaround (as SHFT is DB accessible):
> > Put a couple of dbpf commands at the end of the startup.command script
> > (after iocInit) to set the SHFT fields.
> I think I prefer this as a solution because using raw soft support will
> not be used very often.
I think using signal to specify SHFT is arcane and confusing to begin with, and
it makes an awful mess in the database when you have several parallel ports on the
same card.  I also think requiring that SHFT be specified in the startup file (for
soft support only?) is actually more confusing than allowing it to be specified in
a .db file would be, and makes it impossible to distribute a database that you know
is going to work.
My two cents go toward allowing both signal and SHFT to specify SHFT--using SHFT
if it is nonzero, and falling back on signal only if SHFT is zero.  Every existing
database will work with this choice, and it gives future device support an obvious
prescription for handling more than one parallel port per card.
Tim Mooney
Re: MBBI, SHFT, and GDCT Bob Dalesio
Prev: Re: MBBI, SHFT, and GDCT Marty Kraimer
Next: Re: MBBI, SHFT, and GDCT Bob Dalesio
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: MBBI, SHFT, and GDCT Ralph Lange
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
