1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: setting scan rates
To: [email protected]
Date: Thu, 27 Aug 1998 12:31:05 -0500
re...
> I'm using Epics v3.12.  I added scan rates of .05 second (20 Hz), .025
> second (40 Hz), and .016667 second (60 Hz) to the list in choiceGbl.ascii.
> I rebuilt default.dctsdr and found these three rates added to the file.
> The problem is that scanppl informs me that rates of ".025 second" are
> running at ".016667 second".  A dbgf "record.SCAN" does return the correct
> value of ".025 second".  A logic analyzer says that the scans are occuring
> every 16.7 milliseconds.  The scanPeriod task that these records are in has
> a priority of 51, the second highest priority.
> I did another test where I removed the 60 Hz entry from choiceGbl.ascii and
> saw the same thing.
> I think the records are being processed by the correct scanPeriod task at
> the wrong period.
> Any insight is greatly appreciated.
You can't run at 40 Hz.  Scan rates are restricted to 60/N Hz, where N is an
integer, because scan tasks are driven by a 60-Hz clock.  (Actually, the clock
could run at something other than 60 Hz, in which case you'd be restricted to
sysClkRateGet()/N.)
Tim Mooney
Prev: CapFast special price Dr. Chong Lee
Next: Re: vxWorks/cfitsio question Nick Rees
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: setting scan rates Geoff Savage
Next: CapFast special price Dr. Chong Lee
