1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: S_errno_ENOBUFS
To: "'Pete Jemian'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 28 Aug 1998 16:27:01 -0600
Pete,
On Friday, August 28, 1998 7:02 AM, Pete Jemian [SMTP:[email protected]] wrote:
> What is causing this error message?
> 1998-08-27,22:57:08: 0xc2e7d4 (CA UDP): CAS: UDP send to "164.54.216.13" failed
> because "S_errno_ENOBUFS"
> A couple of IOCs are generating these messages (time/date stamp added by me).
> Tried rebooting the server (164.54.216.13), that did not help.
I see this message from the IOC's CA server when I am testing it under a
heavy UDP load. The server is attempting to send a UDP response frame and
the ENOBUFS error code is returned from the sendto() function. It appears that
this results from a transient congestion in the IP kernel. Since the UDP
portions of CA have built in retransmission timers (as is normal for UDP protocols)
then this situation is benign as long as it is transient. I did not suppress the message
because I felt that it was worthwhile to monitor the frequency of this congestion.
I suspect that this message is scrolling other more important information off of the
screen. I will store an internal counter for these occurrences which will be displayed
by casr, and otherwise suppress the message.
Jeff
Prev: Systems that use EPICS: Design papers? Brian Glendenning
Next: DELETE [email protected] William Spengler
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: S_errno_ENOBUFS Pete Jemian
Next: Bus errors? SIBLEY
