1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: strange ca_array_get results on Linux
To: "'Jeffrey McDonald'" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 3 Sep 1998 13:07:49 -0600
Jeff
This is a known problem.
All of the following must be true prior to experiencing this problem:
o Running on a little endian architecture with signed characters (e.i. Intel
	and probably also VAX)
o Running a CA client that fetches a 2 byte data type such as DBR_SHORT
o The most significant bit of the data is set
o Running a beta release of EPICS R3.13 and perhaps earlier releases also
I have created a potential fix, but not committed it to CVS at this time. A patch will
be installed into the final release of 3.13.
Sorry, I have procrastinated on the bug report for this while finalizing the patch.
An easy workaround for this problem would be to fetch the data as a DBR_LONG.
Thanks for bringing this to my attention, and thanks also to Mark Rivers and Ken
Evans for initially experiencing (and reporting) the problem.
Jeff
On Thursday, September 03, 1998 12:08 PM, Jeffrey McDonald [SMTP:[email protected]] wrote:
> Hi,
> 	Using a slightly modified version of caExample (which comes with
> makeBaseApp), I download 200 parameters to a waveform record using a
> ca_array_put command.
> The record is defined as:
> record(waveform, "$(user):waveForm1")
>         field(DESC, "waveform record")
>         field(NELM, "200")
>         field(DTYP, "Soft Channel")
>         field(FTVL, "USHORT")
> from caExample.c, I do:
>     SEVCHK(ca_array_put(DBR_SHORT,200,mychid,(void *)indata),"ca_array_put
> failure");
>     SEVCHK(ca_pend_io(5.0),"ca_pend_io failure");
>     SEVCHK(ca_array_get(DBR_SHORT,200,mychid,(void
> *)outdata),"ca_array_get failure");
> 	I set the data equal to the array index, e.g. outdata[50] =50.  I
> have defined the indata and outdata to be pointers to short.
> 	When I read-back the data,  on the sgi OS, I get back exactly
> what I expect.  When I read-back data on Linux (Red Hat 5.0), I get the
> correct answer for the first 128 elements, for elements following 128, I
> get:
> 	outvalue = invalue | 0xff00
> 	e.g. for outdata[199]= 65479 = 0xffc7
> 	(for those not hex-speaking  0xc7 is 199)
> 	I have checked to see that the correct values are in the waveform
> record, and they are (the ca_array_put command works correctly). However,
> when the ca_array_get is called, the values for the elements greater than
> 128 are corrupted when they are returned on the Linux box -- but NOT on
> the sgi.
> 	Any ideas?
> 	Thanks,
> 	Jeff
> _____________________________________________________
> Jeffrey McDonald, Florida State   [email protected]
> FNAL MS 352			  phone   630-840-3983
> Batavia, IL 60510                 fax     630-840-8886
Prev: strange ca_array_get results on Linux Jeffrey McDonald
Next: FREE CapFast training license Dr. Chong Lee
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
