Dear Madam/Sir,
I compile R3.13.0.beta12 at LynxOS/x86 platform, LynxOS is real time
UNIX ( www.lynx.com).
1.---------------------------
"make install.host" was finished, I start "caRepeater &" which reports that
CAC: 13 if fnd
CAC: if fnd sl0
CAC: if was down
CAC: could not obtain if flags
CAC: if fnd sl2
AC: if was down
CAC: if fnd lo0
CA Repeater: failed during initialization - no local IP address
"netstat -di" showed that
Name Mtu Network Address Ipkts Ierrs
sl0* 296 <Link> 0 0
sl7* 296 <Link> 0 0
lo0 1536 <Link> 74 0
lo0 1536 loopback-ne localhost 74 0
smc0 1500 <Link>0.0.c0.d5.48.f9 77 0
smc0 1500 private.net FEL-lynxos1 77 0
SLIP devices is sl0-sl7 with "down" status , Ethernet card is
smc0 with "up" status (IP=192.168.3.12).
I used the standard CONFIG_ENV with next parameters
EPICS_CA_ADDR_LIST=""
EPICS_CA_AUTO_ADDR_LIST=YES
2. --------------------------------------------
Next step, SLIP devisces has "up" status, caRepeter workes.
3.--------------------------
I rebuilt the libraries libCom.a and libca.a with a new settings
EPICS_CA_ADDR_LIST=192.168.3.12
EPICS_CA_AUTO_ADDR_LIST=NO
SLIP devices is "down", Ethetnet interface is "up".
caRepeter does not finds IP address.
I the sequence of network devices is inverse at LynxOS.
lo0 is first device.
Could you explain me the way for solution of this problems?
Best Regards,
Tatiana
Budker Institute of Nuclear Physics
prospekt Lavrentev 11
630090, Novosibirsk, RUSSIA
fax +7 3832 342163
phone +7 3832 359977
Re: Two questions about EPICS record support Andrew Johnson
edif executable file Jin Yu
<1998>
2025
Re: Two questions about EPICS record support Tim Mooney
RE: CA at LynxOS/x86 Jeff Hill
<1998>
2025
