1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Limits problems in MEDM
To: [email protected]
Cc: [email protected]
Date: Tue, 22 Sep 1998 18:51:36 -0500 (CDT)
     You are right that MEDM only looks for HOPR and LOPR.  These are
common to most record types, but apparently the Histogram uses
something else.  If you right click on the Cartesian plot in EXECUTE
mode or click on the Axis Data button in the Resource Palette in EDIT
mode, you can set the limits for the Cartesian Plot as you wish.  The
Strip Chart is probably not appropriate for a Histogram or other array
type records, anyway.
     Work is underway on making the limits now set by HOPR and LOPR to
be optionally definable at design time or run time.  This should solve
the problem when the next MEDM version comes out.
	-Ken
Prev: Makefile in R3.13beta12 base Steve Lewis
Next: RE: Limits problems in MEDM Mark Rivers
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Limits problems in MEDM Mark J. Ryan
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
