1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motor record query
To: [email protected]
Date: Fri, 09 Oct 1998 18:19:59 +0200
Len Lawrence wrote:
> A question for motor record gurus.
> I have been using the motor record for some time and have encountered a
> wee problem with stopping a stepper motor after the HOMF or HOMR field
> has been set.
I can imagine. I spent days with the motor record just to find out why
sometimes things you think should happen don't and vice versa. It took
me weeks to finally understand how the record works and how I can make
my changes without breaking everything else.
> I am assuming that HOMF/HOMR will be reset when the home
> switch is encountered so am I right in thinking that the STOP signal
> will be effectively ignored during the home seek operation unless
> HOMF/HOMR is reset?  The documentation on the Web;
> at http://www.aps.anl.gov/xfd/SoftDist/swBCDA/recMotor.html
> does not say if HOMF/HOMR is reset immediately or when the home switch
> is found.
AFAIK, HOMR/HOMF is reset immediately after the home procedure is set
up. The STOP signal obviously should NOT be ignored during a home
procedure, and as far as I remember, this is indeed the case. A STOP
lets the motor record decelerate into a stop under ANY circumstance
(although a stop during the backlash correction phase can take almost
indefinitely long, one of the many reasons I had to rewrite portions of
the record).
Ben
The Notorious Neb Nesknarf
@BESSY II: fax: +49 30 6392-4859 phone: +49 30 6392-4865
keep the listeners happy: BND MAD Waffen Lieferung ETA Lybien IRA CIA
Iran killer Heroin kommunistische Befreiungsfront RAF PKK Irak Kurden
motor record query Len Lawrence
Prev: motor record query Len Lawrence
Next: Re: motor record query Janet Tvedt
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
