1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: IOC communication
To: [email protected]
Cc: [email protected]
Date: Thu, 22 Oct 1998 11:18:57 -0700 (PDT)
 >     Here is what we put in st.cmd to get IOCs to be able to talk both to the
> outside world and to each other:
> routeAdd "0","164.54.160.1"
> routeDelete "164.54.160.0","164.54.160.1"
> which, as I understand it first tells the IOC to go to 160.1 for all
> connections, but then says that any connections on the local subnet should not
> go through this router.
I don't recommend giving VxWorks such a wide-open default, for security reasons.
Unless your router itself (164.54.160.1 in the example above) is carefully
configured--or some external router beyond that is acting as a serious
firewall--you are open to many attacks using TCP.  VxWorks is not very
secure (although it is quite *OBSCURE*).  I do recommend adding just: 1) host
routes to specific hosts that you intend to use CA; and 2) net routes to nets
that you know are truly secure--and have intended CA hosts on them.
Prev: IOC communication Mark Rivers
Next: Power PC floating point underflow William Lupton
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
