1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: HELP - iocs logging to APS
To: [email protected]
Date: Tue, 27 Oct 1998 12:52:37 -0600 (CST)
To all EPICS users:
We are trying to cut down on network traffic at APS and have found out
that MANY iocs outside of APS are trying to log to the APS server phoebus
on port 7004.  This is because a definition in base/config/CONFIG_SITE_ENV
sets the default value for EPICS_IOC_LOG_INET to phoebus' inet number
164.54.8.167. Our firewall prevents access but the firewall is receiving all
the log messages.
You can tell if your ioc is trying to log to phoebus by issuing the ioc
command "epicsPrtEnvParams".
Therefore, if ioc logging is not implemented at your site, I would like to
ask you to help by implementing the following changes -
1)	Remove the reference to phoebus in your CONFIG_SITE_ENV file.
	Before your next build of EPICS base please modify the CONFIG_SITE_ENV
	file and change the definition of EPICS_IOC_LOG_INET to
			EPICS_IOC_LOG_INET=
2)	Disable logging on your iocs
	Ioc logging can be disabled by placing the command line
		iocLogDisable=1
	in your startup command file (st.cmd) before issuing iocInit.
The reference to phoebus will be removed in the next EPICS base release.
Thanks in advance,
Janet
Prev: Warning: snc bug... William Lupton
Next: GPIB CAMAC crate controller Stephen E. Gushue
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
