1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: some database link / simulation issues
Date: Fri, 6 Nov 1998 14:15:35 -0700
On Friday, November 06, 1998 2:03 PM, Jeff Hill [SMTP:[email protected]]
wrote:
> It seems reasonable to pursue catching the special cases you identify
below in the
> database so that CA channels are not created. This is assuming that no
one will need a
> channel named "NPP".
At least for William's case #1 (missing macro definition), it would require
a change in dbLoadRecords(). I'd rather not impose name restrictions on
process variables - even if it is just for "NPP". The appropriate action
would be to have dbLoadRecords to log the error, and:
	o if in record()	- delete the record or dbLoadRecords fatal error.
	o if in field()	- set to the default value
Aloha,
	Peregrine
Peregrine M. McGehee	[email protected] 	(505) 667-3273
Task Leader, LEDA Control System
Deputy Coordinator, Los Alamos Astrophysics	http://laastro.lanl.gov
Prev: RE: some database link / simulation issues Jeff Hill
Next: RE: some database link / simulation issues William Lupton
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
