1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Latch record
To: [email protected]
Date: Wed, 25 Nov 1998 16:41:35 -1000
> First off,  Happy Thanksgiving to my American collaborators and their
> families.
> I want to have a record (or record-set) which emulates a set-reset latch.
> My application is to provide a 'processing-active' flag set while a group of
> record processing and sequences are active.
> The BO record does this (latching function) from a medm page using dbPuts to
> the VAL field,  but I want the same effect based on database processing
> links.  That is,  an FLNK from record 'A' should set the latch (VAL =1),
> and an FLNK from record 'B' should reset the latch (VAL=0).
> I feel like I can't see the forest thru the trees on this one.
I have placed two capfast drawings, that I use for this purpose, in
	ftp.keck.hawaii.edu
	cd pub/epics
	RSFF.sch and RSFFE.sch
RSFF.sch is an implementation of an RS flip-flop using two BO records
and two calc records
RSFFE.sch is similar but it uses 1 fanout record and two calc records such that
the fanout record is used as an enable to cause the flip-flop to latch its
inputs and set its outputs as appropriate.
Allan
Happy TG!
Prev: Solaris 2.6 make of dm richards
Next: RE: caerr.h typo Jeff Hill
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: ????kernel work queue overflow error???? Dale L. Brewe
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
