Steve,
This is a known problem with Channel Access and the new "SENS" IP kernel from WRS.
They (WRS) are defining a macro with the same name as one of the fields
in a data structure used throughout the CA source code.
This problem can be avoided if the "SENS" option is not specified when installing
Tornado.
Jeff
On Monday, December 07, 1998 11:30 AM, Steve Hunt [SMTP:[email protected]] wrote:
> Hi Steve,
> I have not (yet) found where the problem is compiling
> the ca directory for the ppc mv2306.
> As you suggested - could I have a login to your system to
> see how you did it ?
> The problem is related to the struct ca_hdr in caProto.h
> (called from iocinf.h),
> when I change the name m_count to something else, then
> a simple test program compiles ok. Perhaps m_count is
> defined somewhere in the PPC stuff but I can't find it.
> Seems the problem MAY be somewhere in netinet/in.h called from
> osiSock.h
> in.h is different on the ppc than on the 68k includes for
> 1.0.1
> Anyway it must work because you have done it !!! -
> Cheers
> Steve
RE: enhancements to Andrew Johnson's IPC driver Jeff Hill
living without soft links Tim Mooney
<1998>
2025
2026
CDEV activities Chip Watson
<1998>
2025
2026
