1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: tkCVS - tk based GUI for CVS
To: [email protected] (EPICS Tech-Talk)
Date: Tue, 8 Dec 1998 14:55:53 +0100 (MET)
Hi.
Some participants of the European EPICS Meeting last week got to see the
Tcl/Tk based CVS interface we use (public domain) and strongly suggested
this to be put into the EPICS unbundled area. Which I did.
tkCVS supports most of the CVS functions in a very convenient, easy-to-use
way. Even complicated operations (like merging the differences of any two
versions into the main trunk) can be called by clicking a button.
tkCVS calls tkdiff to display differences between versions. tkdiff uses a
dual display and color highlighting to mark differing sections. It may be
used independently from tkCVS as a graphical diff utility.
I put together some screen shots to give an impression of what using
tkCVS/tkdiff feels like. Visit http://www.bessy.de/control/Soft/tkCVS/ to
have a look.
You will definitely like these tools. They save a _lot_ of time. Even
unexperienced unix users will be able to use CVS for revision control.
tkCVS/tkdiff should work with virtually any Tcl/Tk version.
It is available from the APS EPICS repository as epics/unbundled/tkCVS
(module tkCVS).
Hope this helps,
Ralph
Re: tkCVS - tk based GUI for CVS Brian McAllister
Prev: living without soft links Tim Mooney
Next: Re: living without soft links Ralph Lange
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: living without soft links Tim Mooney
Next: Re: tkCVS - tk based GUI for CVS Brian McAllister
