1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Monitors on a stringin record
To: [email protected], [email protected]
Date: Thu, 10 Dec 1998 12:22:22 +0100 (MET)
> Am I correct in assuming that value change monitors are invoked on a
> stringin record *only* if OVAL is not equal to VAL?
Yes.
> Is there any way that a stringin record can be set to trigger monitors
> "ALWAYS"?
Why? Posting a "value change monitor" when the value hasn't changed doesn't
seem quite reasonable for an event based system. (I know the ai record can
work this way if you set MDEL to -1, though.)
If you want your client to be notified whenever the record is processed you
will have to FLNK to another record that either counts (using a calc
record) or just flip-flops (using a closed-loop bo record with DOL pointing
to some "1" and the HIGH field set).
Ralph
Monitors on a stringin record Rosemary Alles
Prev: Monitors on a stringin record Rosemary Alles
Next: Re: living without soft links Ralph Lange
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Monitors on a stringin record Tim Mooney
