1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Links between IOCs
To: "Hammonds, John" <[email protected]>
Cc: [email protected]
Date: Fri, 11 Dec 1998 07:32:43 -0600
"Hammonds, John" wrote:
> Hi all,
> I have been trying to get some links between record in different crates.
> What I am trying to accomplish at this time is a master enable switch
> between two crates for data acquisition.  Crate 1 & Crate 2 both have an
> enable record (a bo).  The enabled signal is passed in hardware from crate1
> to crate2.  I would like to pass the two enables into the INPA and INPB
> field of a calc record.  I have FLNK'd both to a calc record in the fist
> crate(cross crates to the .PROC field according to some docs).  The val
> field of the bo's are passed into the approriate INPx.   The VAL field of
> the calc is then passed to the master enable record's DOL, yes I'm in Closed
> loop here.  The first enable, the one in the the same crate, passes to the
> calc fine but I see no changes to the 2nd.  dbpr on the calc and on the
> bo's. shows that the links have been made.  The first bo shows as a DB_LINK
> and the second shows as a CA_LINK.  The forward link from crate 2 also shows
> as a CA_LINK.
> It does not seem that changing the 2nd enable's VAL has any effect at all in
> crate 1.  I checked this by shitching TPRO in the calc record.
> Any hints from the gurus?
> I am using R3.13.0.b4 on the IOCs by the way.
Could you reproduce the problem with the minimum set of records/fields and let
us see the databases.
I looked quickly and did not see any difference between R3.13.0.b4 and the
current release that explains the problem.
Marty Kraimer
Links between IOCs Hammonds, John
Prev: RE: Links between IOCs Maren Purves
Next: Re: Monitors on a stringin record Mark Rivers
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Links between IOCs Hammonds, John
Next: Re: Links between IOCs Tim Mooney
