1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Monitors on a stringin record
To: [email protected]
Cc: [email protected]
Date: Fri, 11 Dec 1998 12:02:34 -0600
re...
> I was under the impression that even if a
> record requested that monitors be posted on a field which had not changed,
> that channel access would not actually post the monitors if the values were
> the same.  Is this true?
No.  If a record calls db_post_events() the field will be posted, regardless
of its value.  Channel access will not overrule the record.
Tim Mooney
Prev: RE:PC Fonts.... schoeneburg
Next: Activity logging Rolf Keitel
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Monitors Marty Kraimer
Next: RE: Monitors on a stringin record Jeff Hill
