1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: question about medm and the .PREC field
To: [email protected]
Date: Mon, 14 Dec 1998 16:54:40 -0700 (MST)
Dear MEDM Gurus
	I am using a special record developed at JLab to control LeCroy
1458 High Voltage mainframes and associated modules.  This record and its
associated support works very well.  However, the record definition doesn't
include a .PREC field.  This seems to produce the result, when I display
the voltages and currents in a medm gui in "decimal" format, that I only
see integer values.  Unfortunately, the first (and sometimes second)
decimal place in the voltage and/or current contains information that I
would like to see.  If I just add a .PREC field to this record and give it
a value of 1 or 2, will medm "do the right thing" ?  Please note:  This
special record does not make use of the .VAL field.  Instead, the values of
interest are stored in other fields (essentially .VOLTAGE and .CURRENT)
which I display in the medm gui.  So I am really asking if the .PREC field
will influence the display of these other fields in the record.
					yours,
						Steve Pate
Stephen Pate		Department of Physics		office:   505-646-2135
			Box 30001, Dept. 3D		dept:     505-646-3831
			New Mexico State University	fax:      505-646-1934
[email protected]		Las Cruces NM 88003		home:     505-382-6880
Prev: Java Native Interface for Channel Access Functions Janet B. Anderson
Next: Re: question about medm and the .PREC field Tim Mooney
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CA and Java Eric Boucher
