1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: FW: comp.os.vxworks newsdigest
To: "EPICS-tech-talk (E-mail)" <[email protected]>
Date: Wed, 20 Jan 1999 10:23:31 -0700
All,
overheard this on the WRS exploder
Jeff
Newsgroups: comp.os.vxworks
Subject: Re: PCB chain corruption
Date: 14 Jan 99 20:06:23 GMT
Organization: Centre for Research in Earth and Space Technology
Message-ID: <[email protected]>
References: <[email protected]>
Next use 'mbufShow' to be sure that there are enough network buffers
available. In particular the "number of times drained protocols for space"
line should show 0, otherwise your system has been running out of mbufs.
Raise the max mbufs limit and rebuild your VxWorks image to get around this.
We've found that protocol "draining" can cause serious problems,
including network access delays and the apparent "stranding" of mbufs
resulting in permanent loss (this is probably a bug somewhere in VxWorks).
Good luck,
Georg
Georg Feil
                                             | http://www.sgl.crestech.ca/
Space Geodynamics Laboratory                 | Email: [email protected]
CRESTech                                     | Phone: (416) 665-5458
4850 Keele St./North York/Ont/Canada/M3J 3K1 | Fax: (416) 665-1815
Prev: RE: EPICS on cPCI/PPC Jeff Hill
Next: base/src/gdd/dbMapper.cc bug saa
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: alarm handler Jeff Hill
