1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: X-terminals & EPICS security
To: [email protected] (Ned D. Arnold)
Cc: [email protected] (EPICS Tech-Talk)
Date: Thu, 21 Jan 1999 17:54:23 +0100 (MET)
> > Is there a way I can configure the access security configuration file to use
> > the names/IP address of the individual X-terminals ?
> No.  I was told <since Channel Access Security was born> that to implement this
> feature would make it difficult to port to other operating systems. I was
> encouraged to do this with "prudent system administration" rather than
> channel access security. I never figured out how to do that either.
Based on the experiences with X-terminals using the "old" (i.e. pre-EPICS)
BESSY I control system I would start thinking in the following direction:
 o Create (additional) different special OPI user accounts for the
   different X-terminals (or security relevant groups of X-terminals) on
   your mainframe.
 o There must be a script-like thing that runs the X-session for the
   generic OPI user (this heavily depends on your system). Insert something
   at the beginning that evaluates $DISPLAY and execs a "su" login shell
   for the appropriate terminal-dependent special OPI user which then
   starts the X-session for the special user.
 o Start all the special OPI users' interactive login shells with calling
   exit if $DISPLAY is not set correctly.
 o Be careful about file permissions. In order to share files between
   different OPI users/X-terminals you might have to create a new group
   for all the special OPI users and set the umask to make everything group
   writable.
 o Configure your CA Security to work by user instead of by host.
This is just a first thought. I don't claim this to be elegant at all.
Or even working.
Ralph
Re: X-terminals & EPICS security Ned Arnold
Prev: Re: X-terminals & EPICS security Gary Carr
Next: Re: Slow booting ioc Garrett D. Rinehart
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: X-terminals & EPICS security Ned Arnold
Next: Re: X-terminals & EPICS security Gary Carr
