1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Multiple C++ based CA servers on the same host and port number
To: "EPICS-tech-talk (E-mail)" <[email protected]>
Date: Thu, 28 Jan 1999 14:44:40 -0700
All,
A known problem exists with the C++ based server library (which is not
used in the IOCs but is used with newly developed server side tools).
If you run more than one CA server tool on the same host with the same
server UDP port number then the CA clients will see beacons from both
of these servers as one server, and they will falsely conclude that the
server beacon period is changing erratically. This will lead client's with
disconnected PVs to continuously conclude that there is a newly available
server on the network, and therefore broadcast at a benign but faster rate
than is normal. These clients will not back off to a slower broadcast rate
as the they see that they are not responded to because they will continuously
conclude that a new server is on the network.
Because of the above problem I don't recommend that sites run more
than one server on the same UDP port number on the same host
(probably a rare configuration in the past due to IP kernel limitations)
until a solution to this problem is installed.
Jeff
______________________________________________________
Jeffrey O. Hill                      Internet     [email protected]
LANL MS H820                    Voice         505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Prev: RE: base/src/gdd/dbMapper.cc bug Jeff Hill
Next: WaveForm Generator Miroslaw Dach
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Joerger Wave Form ADC Miroslaw Dach
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
