1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: dbst problem when built against 3.13.1
To: [email protected]
Date: Mon, 01 Feb 1999 11:20:34 -0800 (PST)
Hello -
Recently, I rebuilt a subset of extensions against R3.13.1
(with a little more effort than anticipated - I thought it would
be a matter of changing a few CONFIG files and rebuilding - Not!).
So far, the extensions that we use are all working as before except
for dbst, the tool that checks .db files and strips out unnecessary
lines.  I believe dbst is used mostly by people who generate .db
files from CAPFAST schematics via e2db.
The R3.13.1 dbst does not strip out fields that are initialized to
zero.  As a result, the .db files it generates are significantly
bigger and IOCs take longer to reboot.  Also, it can affect bumpless
reboot if you restore your subroutine/calc inputs before
InitHookafterInitDatabase (the zeros will override what you restore
for these).
Has anybody seen this problem and fixed it?  My first guess is that
there is a change to some dbStatic routine that is called by dbst.
Thank you,
Stephanie Allison
Prev: Re: wdTimer & EPICS sequencer Andrew Johnson
Next: Re: dbst problem when built against 3.13.1(actually problem with capfast symbols) Rozelle Wright
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
