1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Record support question
To: [email protected]
Date: Tue, 23 Feb 1999 14:55:34 -0800 (PST)
I am creating a custom record, and have defined a field in the record to
have special processing at run time (special = SPC_MOD) and have the pp_value
set to YES (a passive record should be processed when Channel Access writes
to this field).
In the record support code I have a routine called special, that simple sets
a flag to indicate that the record was accessed - and then expect that
after special the "process" routine should be called.
Well, this appears to work as expected - most of the time.  Sometimes I
see that special is called and then some time later - much later -
the process gets called by "scanOnce".  This is a problem because I
set a timer (using the watchDog timer lib - wdLib), to keep time and tell
me if I have waited too long - and this times out before the process
gets called.
So, sequence of events is:
-start watchdog timer at time <72103>
-value written to SPC_MOD field <73003> in an interrupt routine from a different
record.
-special is executed and flag gets set <73003>
-then some time later the watchdog timer finishs <73904> and the callback
routine gets called.
-and immediately following the process gets called as a result of the
special being executed, but this is much too late <73904>.
So, can anyone help me?  I have a feeling it has to do with running the
watchdog timer, but can't tell.
I am running EPICS 3.12.2 & vxWorks on an MV167.
Jennifer Dunn
Re: Record support question Marty Kraimer
Re: Record support question Benjamin Franksen
Prev: AB DCM mbbi input specification Bill DeVan
Next: atdb - dct (KP_R? keys) Matthieu Bec
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Record support question Marty Kraimer
