1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dbst problem when built against 3.13.1(actually problem with capfast symbols)
To: Rozelle Wright <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 03 Mar 1999 19:03:01 +0100
Hi Rozelle,
> > Hi Ben,
> > Did you ever write that Perl script?
> Unfortunately not! I could not decide to make the changes in our
> edif-sym directory because I feared that older applications (using older
> epics releases) might break. [...]
My fears were not justified. I didn't realize that dbst is an epics
_extension_ and therefore has only one instance at our site and not one
for every base release, like eg dbLoadRecords. So we have been using the
new dbst all along.
Anyway, we are currently trying to adjust our site to the new
source/release control. Thus we treat the directory for capfast symbols
and edb.def like a <supporttop> so the cleansed direcory is used only
for 3.13.1 applications. This is my 'script':
perl -pi -e 's/:0(\.0+(e\+0+)?)?$/:/g' *.sym
perl -pi -e 's/\(default\("0?(\.0+(e\+0+)?)?"\)\)//g' edb.def
perl -pi -e 's/\(default\s+"0?(\.0+(e\+0+)?)?"\)//g' edb.def
It eliminates all zero values in the symbols, as well as all zero value
and empty string defaults in the edb.def (no backup). Do existing
schematics need be cleansed of zeros? In any case, I wouldn't do it
automatically because there may be zeros that are meant to be in there
to override other defaults. I don't think we need to edit any capfast
symbol or edb.def manually.
Ben
The Notorious Neb Nesknarf
@BESSY II: fax: +49 30 6392-4859 phone: +49 30 6392-4865
keep the listeners happy: BND MAD Waffen Lieferung ETA Lybien IRA CIA
Iran killer Heroin kommunistische Befreiungsfront RAF PKK Irak Kurden
Prev: RE: Labview CA interface? Jeff Hill
Next: Re: dbst problem when built against 3.13.1(actually problem with capfast symbols) Rozelle Wright
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
