1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: CA beacons
To: "'[email protected]'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 15 Mar 1999 15:42:37 -0700
Brian,
On Tuesday, March 09, 1999 1:10 PM, Brian McAllister [SMTP:[email protected]] wrote:
> Is there a document that describes the CA beacon "system" ?
There isnt a document dedicated to this subject, but these sections from the CA
reference manual do provide a high level description of what is occurring. Feel
free to contact me if you have more detailed questions.
Jeff
1.3 CA and Wide Area Networks
Normally in a local area network (LAN) environment CA discovers the address of the host for
an EPICS channel by broadcasting frames containing a list of channel names (CA search messages)
and waiting for responses from the servers that host the channels identified. Likewise CA clients
efficiently discover that CA servers have recently joined the LAN or disconnected from the LAN by
monitoring periodically broadcasted "beacons" sent out by the servers. Since hardware broadcasting
requires special hardware capabilities, we must provide additional configuration information
when EPICS is extended to operate over a wide area network (WAN).
If CA has not seen a beacon from a server that it is connected to for EPICS_CA_CONN_TMO seconds
then an echo message is sent to the server over TCP/IP. If this echo message isn't replied to by the server
within 5 additional seconds then the client will assume that the server is no longer present on the network
and disconnect. Disconnecting implies notification of any application programs that may be using Channel
Access to communicate with the server in question. Disconnecting also implies releasing any resources
reserved while communicating with the missing server. The parameter EPICS_CA_CONN_TMO is specified
in floating point seconds. Note that for short time outs, the delay until disconnect will also depend on the
rate at that applications poll into the CA client library (and allow CA background activity to be attended to).
When a CA server initializes it initially sends "beacon" messages to each address specified in
EPICS_CA_ADDR_LIST, and also any addresses auto configured from network interfaces found, with a very
short period between "beacons". However, this short period is doubled each time a "beacon" is sent so that it
will rapidly reaches a plateau specified by EPICS_CA_BEACON_PERIOD. The parameter
EPICS_CA_BEACON_PERIOD is specified in floating point seconds. For efficient operation it is
recommended that EPICS_CA_BEACON_PERIOD be set to at least one half of the value specified for
EPICS_CA_CONN_TMO.
Prev: Re: EPICS on x86 Brian McAllister
Next: pcompress->alg == compressALG_N_to_1_Median William Lupton
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: CA beacons Brian McAllister
Next: Installing epics on Sun Solaris john sinclair
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
