1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: IP-packs, IP carriers, and Backplanes vs. CPUs - endian issues
To: Bill Brown <[email protected]>
Cc: TECH-TALK <[email protected]>
Date: Fri, 26 Mar 1999 13:35:45 -0600
Bill Brown wrote:
> So - the question I propose is, "Where should the byte-swapping
> code go?"
> It seems logical (to me) that a good place would be in the carrier
> driver, but that is not without it's problems.  I suspect that no
> matter where we put it, we'll have some cpu/backplane dependencies
> seeping into areas where we don't want it.
Some of Jeff's changes to drvIpac resolve this for both endian models; as
long as you access the registers on the module using word rather than byte
read/writes then the endian issue is handled completely by the hardware.
Thus within drvIpac.h the prom structure has been redefined to use short
integers (16 bits).  The drvIpac.c code is also changed so the upper byte
of these values is discarded, and I'm thinking about making parallel
changes to my drvTip810 CANbus module driver.  IMHO this is the way to
solve the problem as the same code works for both CPU types without having
to know what kind of CPU you're using.  It may be that this method can't
be used for all I/O modules, so I'm open to argument about this.
The updated support will be included with Verion 2.1 of the ipac software.
The latest release of Version 2.0, full documentation and some earlier
releases are now available at
	http://epics.aps.anl.gov/asd/people/anj
- Andrew
New country, job, address, car and signature; same old Andrew Johnson
Re: IP-packs, IP carriers, and Backplanes vs. CPUs - endian issues Bill Brown
Prev: IP-packs, IP carriers, and Backplanes vs. CPUs - endian issues Bill Brown
Next: What does EV recDynINP do ? David Terrett
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: IP-packs, IP carriers, and Backplanes vs. CPUs - endian issues Bill Brown
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
