1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS Channel Access
Date: Tue, 11 May 99 13:29:50 CDT
	I am trying to obtain some information on an Channel Access Server
problem currently being experienced at a new EPICS site.  The NT Client
application is based on the EPICS 3.12 library - when started, the
appropriate Win-SOC window open along with the caRepeater and application
windows.  The EPICS CA Diagnostics display illustrates connection to
sockets and communications can exist successfully for several minutes.  At
the end of 10-15 minutes, the diagnostics window displays a message
pertaining to the Server not able to allocate additional memory for
channels.  Is this a sign of a Client issue or Server issue ? Anyone
experience this before ? and what checks can be done on CLient or Server
side (Client NT, Server UNIX) to find the root cause of the problem ?  Any
information is greatly appreciated, thank you for your time.
Mike
**This message was created in BeyondMail. Please ignore the ATTRIBS.BND
attachment if you are not a BeyondMail user.
Prev: Re: gpib device Noboru Yamamoto
Next: Re: mv230x floating point underflow Kevin Tsubota
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS Channel Access Michael J. Feldhake
Next: 14 or 16 bit IO boards Garrett D. Rinehart
