1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: gpib device
Date: Wed, 12 May 1999 21:19:10 +0900
>>> On Mon, 10 May 1999 07:46:10 -1000,  Maren Purves <[email protected]>  wrote;
> question, as I'm looking into GPIB-Ethernet or GPIB-RS232 'converters'
> at the moment: does the HP-2050A support secondary addressing?
> We need to be able to connect remotely as well as have secondary
> addressing.
ET-488 from Tektronix, which Noboru mentioned, can handle secondary
addresses.  I may evaluate HP-2050A as well soon.
>>> On 11 May 1999 10:56:03 JST,  "Noboru Yamamoto" <[email protected]>  wrote;
> We use a similar Ethernet-GPIB bridge made by Sony-Tektronics
> called ET-488( which may not available outside JAPAN).
As I saw an advertisement thru Tektronix at CERN sometime ago, I
think it's available in the U.S as well, although it was developed
by Sony-Tektronix in Japan.
> It works fine in EPICS environment unless your device does not
> use SRQ.
> ET-488 sends SRQ signal using SIGURG signal which is NOT defined
> in VxWorks.
ET-488 sends SRQ via out-of-band data on a TCP channel.  vxWorks
should be able to receive it via some mechanisms.  Actually I
proposed to use out-of-band TCP data for SRQ when they were
designing ET-488 in 1991.  Unfortunately it cannot use UDP to
transfer GPIB data, and using TCP only one client can connect to
ET-488 at a time, even though several GPIB devices are connected
with it.
> I'm just curious how HP-2050A can handle SRQ.
Regards, Kazuro.
Kazuro FURUKAWA <[email protected]>
 High Energy Accelerator Research Organization (KEK), Japan
Prev: LeCroy 1440 HV support Burkhard W. Kolb
Next: Joining the EPICS Tech-Talk Maria Tzamtzi
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: gpib device Noboru Yamamoto
Next: Re: gpib device Noboru Yamamoto
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
