1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Changing caRepeaters
Date: Wed, 16 Jun 1999 10:46:22 -0600
> What are your thoughts on using multicasting instead of "CARepeater
> mechanism"?
The repeater solves the following problems:
1) pre-multicast kernels do not allow more than one process to
bind to the same UDP port, and therefore broadcasts and unicasts
are delivered to only one process.
2) in most modern IP kernels UDP broadcasts can be sent to multiple
processes, but unicasts can be sent to only one process.
I will definitely be looking at multicasting in future versions since
multicasting is becoming universally available. At this point I
believe that the new SENS vxWorks IP stack and most any other IP
kernel will support multicasting. The SENS stack also supports
DNS and NTP. Backwards compatibility may introduce some
complications however, and at this point some of the details concerning
the above two issues and multicasting still need to be investigated.
Jeff
Prev: Re: Changing caRepeaters Arun Bommannavar
Next: Apology for Error-Mails Ralph Lange
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: EPICS meeting before ICALEPCS-99 Matthias Clausen
