1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: channel access time response
To: [email protected]
Date: Wed, 21 Jul 1999 10:03:38 -0500
I have a couple of naive questions about the time period between a database
field change and its transmission to ca clients monitoring the field. I
gather a low priority thread does this job and that therefore this might
have significant variation? Is there a lower limit? I've seen reference to
the EPICS "clock tick" of 1/60sec - is this the maximum rate that changes
are transmitted via monitors? Do similar considerations apply for records
using CA input links, e.g. wait records?
Thanks
Dale Brewe
 Dale L. Brewe     PNC-CAT/U. of Washington
 ph: 630 252 0582         fax: 630 252 0580
 Mail:
 Argonne National Laboratory/APS
 Bldg 435E sector 20
 9700 S. Cass Ave.
 Argonne, IL 60439
RE: channel access time response Jeff Hill
Prev: Re: GreenSpring IP-DAC driver? Bill Brown
Next: String PVs and the Portable CA Server. Brian Tieman
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: drvAbDf1 and PLC-2 Jeff Hill
Next: RE: channel access time response Jeff Hill
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
