1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Y2K
To: [email protected]
Date: Mon, 26 Jul 1999 12:20:06 -1000
We have been upgrading and running Y2K tests on our systems.
I was sure that the EPICS components would have no trouble,
mainly based on everything I had heard and read.
Well, I got quite a surprise when our system display showed
1 Jan 1900!  Turns out that tsStampToText() is used to break
out the timestamp (which itself is OK), and it only has an
option for a "YY" type format.  Unfortunately this function
call is at the heart of our system.  We are running R3.13.beta11,
in case there are version differences in this area.
So, a word to the wise might be to check into timestamp
formatting.  I'm thinking we will replace the timestamp to
text and text to year, month, day, etc. back-to-back
conversions with a single routine that does everything (right).
William L. Cruise                             [email protected]
Electronics System Supervisor                   FAX:    808 885-7288
Canada-France-Hawaii Telescope                  Voice:  808 885-3122
P.O. Box 1597                     http://www.cfht.hawaii.edu/~cruise
Kamuela, HI   96743
Re: Y2K Andrew Johnson
Prev: Re: How do you know if you are accessing a shared resource? Tim Mooney
Next: Re: Y2K Andrew Johnson
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: mbbiDirect record Leonard J. Reder
