1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
To: "EPICS-tech-talk" <[email protected]>
Cc: "Dehong_Zhang" <[email protected]>
Date: Wed, 11 Aug 1999 13:55:00 -0600
All,
Dehong Zhang has discovered a problem where database fields
with the SPC_NOMOD attribute set are not always seen by Channel
Access clients to have no write access. I have patched R3.13.1
so that proper access rights state is propagated to the Channel
Access client API. Rest assured that the database will reject
requests to modify SPC_NOMOD fields even if the client is
incorrectly informed that there is write access.
Jeff
______________________________________________________
Jeffrey O. Hill           Internet     [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Prev: TEWS TIP810 Replacement? W T Meyer
Next: dynamic INP/OUT evaluation Luedeke Andreas
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: TEWS TIP810 Replacement? Matthias Clausen
