1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer on Host system (or something similar)
To: [email protected]
Cc: [email protected]
Date: Tue, 17 Aug 1999 15:09:43 +0100
Hi Mathias,
I ported channel access client for Python, yet another scripting language.
Python provides among others object oriented constructs and your code might endup
looking better than simple Tcl.
Note this is primarily intended as a command line interpreter,
you could plugin Tk and create GUI .. but I guess that brings you back to the
original problem.
you can get a preview at:
     http://www.ing.iac.es/~mdcb/pythonCA.html
(note I've been informed other people have worked on python)
You could also consider loading the tcl OO extension (itcl), which helps a lot
structuring code,
Cheers,
 Matthieu.
Matthieu Bec                       Isaac Newton Group
tel  : +34 922 425427              Apartado de Correos 321
fax  : +34 922 425401              38780 Santa Cruz de La Palma
url  : www.ing.iac.es/~mdcb        Canary Islands, Spain
[email protected] wrote:
> [...] Is there a sequencer or any other resaonable way to
> implement procedures on the host system that control several PVs.
> I had a look at tcl_et, but I would prefer a more restricted language for the
> user interface and probably even for the state machine.
> Thanks,
> Mathias
Sequencer on Host system (or something similar) Mathias . Muench
Prev: Sequencer on Host system (or something similar) Mathias Muench
Next: State machines with channels from other IOCs Kenneth Kang
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Sequencer on Host system (or something similar) Mathias . Muench
Next: Sequencer on Host system (or something similar) Mathias Muench
