1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: network problem w/ ioc
To: "Dale L. Brewe" <[email protected]>
Cc: [email protected]
Date: Wed, 25 Aug 1999 09:08:39 -0400
Dale,
Your problem is similar to one I tracked down at PSI. If you
have a gateway (default routing node) improperly set in the
boot parameters of the IOC, then the following scenario can
happen:
(1) the first client connects, but the ioc sends all traffic for
that client through the gateway
(2) the gateway eventually sends a message to the ioc telling it
what the correct ethernet address for that host is (it doesn't want
to carry traffic unnecessarily)
(3) the ioc mistakenly updates the gateway address instead of
installing an explicit host entry
(4) the second client connects, and the ioc attempts to route
all traffic through the gateway again, but now it uses the
"updated" address for the gateway, which is client one
(5) client one refuses to forward the packets (lazy, huh?), so
the ioc appears to drop off the net for everyone except the
first client to have connected
Log into the ioc via the console if you can, and you can watch
this scenario play out.  Then, check your boot parameters and
either fix or remove the gateway entry.
Chip
Re: network problem w/ ioc Dale L. Brewe
Prev: Re: DM Channel Popup Enhancement Ron Chestnut
Next: Re: DM Channel Popup Enhancement Chip Watson
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: network problem w/ ioc Jeff Hill
Next: Re: network problem w/ ioc Dale L. Brewe
