1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: network problem w/ ioc
To: Maren Purves <[email protected]>
Cc: Chip Watson <[email protected]>, [email protected]
Date: Wed, 25 Aug 1999 15:03:06 -0500
It seems the routing is in fact getting screwed up in some way. What seems to work is to add "routeAdd" lines to the ioc startup w/ the most necessary workstations. This has been working for an hour or so thus far. Thanks for everyone's help.
Dale
At 01:14 PM 8/25/99 , Maren Purves wrote:
Dale,
yes, the routers could act differently depending on how they are/were
programmed. We don't use "routeAdd" as long as we stay on the same
subnet. I just looked up an old startup file where the ioc (temporarily,
we were still testing then) was on a different subnet than the devices
it was connected to, and in that case we used a routeAdd that had the
router's address and the subnet specified.
My understanding is that a routeAdd "0" , "x.x.x.x" tells the router
that all traffic is going "out" (and the programming of the router
decides whether "out" really means "out" or not).
Maren Purves
Dale L. Brewe wrote: > > Chip > Well, something along these lines seems plausible, I guess, altho the > gateway has not changed, nor have the ioc parameters. However, these > problems surfaced a few days after a new main switch/router was installed. > Clearly the problem seems to be at a pretty basic level, as I have troubles > pinging the ioc with no CA clients running. I haven't found anything that > looks bad in either hardware or software. In the ioc startup, I have > routeAdd "0", "x.x.x.x" for our subnet gateway. Is this correct? It worked > before, but could the routers be acting differently for some reason? > Dale > At 08:08 AM 8/25/99 , Chip Watson wrote: > >Dale, > > > >Your problem is similar to one I tracked down at PSI. If you > >have a gateway (default routing node) improperly set in the > >boot parameters of the IOC, then the following scenario can > >happen: > > > >(1) the first client connects, but the ioc sends all traffic for > >that client through the gateway > > > >(2) the gateway eventually sends a message to the ioc telling it > >what the correct ethernet address for that host is (it doesn't want > >to carry traffic unnecessarily) > > > >(3) the ioc mistakenly updates the gateway address instead of > >installing an explicit host entry > > > >(4) the second client connects, and the ioc attempts to route > >all traffic through the gateway again, but now it uses the > >"updated" address for the gateway, which is client one > > > >(5) client one refuses to forward the packets (lazy, huh?), so > >the ioc appears to drop off the net for everyone except the > >first client to have connected > > > >Log into the ioc via the console if you can, and you can watch > >this scenario play out. Then, check your boot parameters and > >either fix or remove the gateway entry. > > > >Chip
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Dale L. Brewe PNC-CAT/U. of Washington ph: 630 252 0582 fax: 630 252 0580 Mail: Argonne National Laboratory/APS Bldg 435E sector 20 9700 S. Cass Ave. Argonne, IL 60439 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
network problem w/ ioc Dale L. Brewe
Re: network problem w/ ioc Dale L. Brewe
Re: network problem w/ ioc Maren Purves
Prev: Re: bug in EPICS R3.13 and R3.12 Kenneth Kang
Next: RE: network problem w/ ioc Jeff Hill
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: network problem w/ ioc Maren Purves
