1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Calling all Power PC EPICS sites
To: Benjamin Franksen <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 01 Sep 1999 10:13:41 +0200
Benjamin Franksen wrote:
> Timo Korhonen wrote:
> > I also had a similar problem with GPIB support (we are using the HPE2050 LAN
> > gateway support
> > from Benjamin Franksen at BESSY) when porting device support modules.  When I
> > removed the "static"
> > keyword in devGpib.h :
> > /*static*/ struct devGpibParmBlock devSupParms;
> > the drivers started to work. When declared static, the data that was supposed
> > to be in the structure was
> > not correctly passed from the init routine to the records.
> > These changes seemed to work, but does somebody have an explanation why?
> This is a compiler bug of gcc in the version that is shipped with
> VxWorks 5.3.1. See the thread starting with
> http://www.bessy.de/MailLists/b-tech-talk.1998/frm00696.html (in which I
> stated wrongly that it would be ok to change static to extern, Marty
> convinced me otherwise).
I tested the example that was in Marty's posting and it seems that our
cross-compiler
(gcc 2.8.1) does not have that bug.  So the explanation (in our case) must be
elsewhere.
> > On the other hand, this seems sort of logical because static variables are
> > valid only within a program
> > unit (according to my textbook), but why does this then work with a 68k cpu?
> Well, the static variable 'devSupParms' never used _directly_ by other
> modules, so it can and in principle should be private (ie 'static'). It
> furthermore _must_ be private at least if you have more than one GPIB
> device support, lest you get a name clash.
Here I was pointing more to the OMS58 driver problem. Sorry for mixing two
different things, but I thought the origin probably is the same and I was looking
for
enlightment on that issue. And I did get a reply ;-)
The name clash I had (painfully) noticed, with the two GPIB devices I have on my
desk.
But I had missed the proposed fixes, although I had seen those postings (on my
own,
I arrived at individually naming the devSupParms individually per device, which I
did
not like at all).
> > I will submit the full patches (diffs) if people agree that these changes
> > make sense. Or is there a better way to fix this problem?
> Well, yours will work only with one GPIB device support, so I think you
> have to stay with the above 'solutions', even though I dislike both of
> them.
For the GPIB, we clearly have to stay with those solutions. Now that the problems
are
more clear, I can go ahead with GPIB (although I share your disliking).
What I was more referring to was the motor control patch. There I dont see a
similar problem
with name clashes (experts, please correct me if I am missing something crucial
!), because the
called function is unique and handles any number of OMS58 cards. In this sense,
the motor
driver patch seems to be a more valid solution, although it would be cleaner to
keep the
function static,  if there was a way to make it work.
Timo
Timo Korhonen  PSI (Paul Scherrer Institut), SLS
               CH-5232 Villigen PSI
               tel + 41- 56 3103262  fax + 41 - 56 310 4413
e-mail:        [email protected]
Calling all Power PC EPICS sites Andrew Johnson
Re: Calling all Power PC EPICS sites Timo Korhonen
Re: Calling all Power PC EPICS sites Benjamin Franksen
Prev: RE: Need an EPICS supported "peak sensing" ADC Mark Rivers
Next: workQPanic! Oh no! Mark M. Ito
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Calling all Power PC EPICS sites Benjamin Franksen
Next: Build problems Dave Reid
