1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: curious OMS58 Problem / Waveform-Size-Limitation
To: [email protected]
Date: Wed, 15 Sep 1999 23:34:36 +0200
we experienced a strange behaviour of an OMS58 Motor-card.
If the OMS58-card is jumpered for base address 0xc000, the motor
suddenly stops, starts again and it needs several retries to reach its
destination.
We tried various cards in different crates and this only happens if the
card has base address 0xc000, even if there are no other cards in the
crate.
Anyone an idea, what this could be?
Another question concerns the maximum message size of CA-messages.
We use Mark Rivers MCA-Record with the Canberra AIM556 MCA, which is
based on the Waveform-Record. If I try to read more than 4090 channels
(~16360 bytes), we get the CA-error "data does not fit in a CA-message".
In caProto.h MAX_MSG_SIZE is defined with 16384 (16*MAX_UDP).
Is it safe to define MAX_MSG_SIZE at least to 33*1024, (for CA-Server
and Client)
or is there another way to do it?
Thanks in adv.
Jens
Jens Eden
PTB
Re: curious OMS58 Problem / Waveform-Size-Limitation Andrew Johnson
RE: curious OMS58 Problem / Waveform-Size-Limitation Jeff Hill
Prev: Re: Generic Fieldbus Device Support (GPIB and others) Marty Kraimer
Next: Tornado Tool usage. Ron Sluiter
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: LeCroy 1458 High voltage mainframe support Coles Sibley
Next: Re: curious OMS58 Problem / Waveform-Size-Limitation Andrew Johnson
