1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem w/ 3.13.1 -> 3.13.1.1
To: [email protected]
Date: Fri, 08 Oct 1999 11:15:35 -0500
Oops - never mind, I realized I had to use a modified module_types.h and it now builds, at least.
Dale
At 09:03 AM 10/8/99 , Dale L. Brewe wrote:
I have a problem building a simple application under 3.13.1.1 that builds ok under 3.13.1. It involves a driver for a VMIC 4116 ao board. The command gmake is using to compile drvVmi4116.c is
/usr/local/epics/vx/vxV52p1/vw/../vxgccV2.2.3.1/solaris.68k/bin/cc68k -B/usr/local/epics/vx/vxV52p1/vw/../vxgccV2.2.3.1/solaris.68k/lib/gcc-lib/ -nostdinc -ansi -pedantic -O2 -fstrength-reduce -Wall -DCPU=MC68040 -m68040 -DCPU_FAMILY=MC680X0 -DvxWorks -DV5_vxWorks -fno-builtin -I. -I.. -I../../../include -I/home/epics3/Appl/synApps/share/include -I../../../include -I../../../include/os/vxWorks -I/usr/local/epics/3.13/base/include -I/usr/local/epics/3.13/base/include/os/vxWorks -I/usr/local/epics/vx/vxV52p1/vw/h -c ../drvVmi4116.c
I get several apparently "normal" warnings, culminating in
../drvVmi4116.c: At top level:
../drvVmi4116.c:49: warning: `sccsID' defined but not used
gmake[3]: *** [drvVmi4116.o] Error 1
gmake[3]: Leaving directory `/home/epics3/Appl/synApps_R3.13.1.1/pnc/idApp/src/O.mv162'
I also noticed that for some reason vxWorks and vxWorks.sym were not installed in the build of 3.13.1.1, so I'm not 100% sure the base build was ok, but it did complete. This is happening under solaris 2.5.1, vx 5.2p1.
I'd appreciate any help.
Dale Brewe
 Dale L. Brewe     PNC-CAT/U. of Washington
 ph: 630 252 0582         fax: 630 252 0580
 Mail:
 Argonne National Laboratory/APS
 Bldg 435E sector 20
 9700 S. Cass Ave.
 Argonne, IL 60439
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Dale L. Brewe PNC-CAT/U. of Washington ph: 630 252 0582 fax: 630 252 0580 Mail: Argonne National Laboratory/APS Bldg 435E sector 20 9700 S. Cass Ave. Argonne, IL 60439 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
problem w/ 3.13.1 -> 3.13.1.1 Dale L. Brewe
Prev: problem w/ 3.13.1 -> 3.13.1.1 Dale L. Brewe
Next: Problem with epics alarm Sue Witherspoon
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
