1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: CA task list
To: "EPICS-tech-talk" <[email protected]>
Cc: "Hamid Shoaee" <[email protected]>
Date: Thu, 21 Oct 1999 16:27:12 -0600
All,
Attached is a task list for CA V4 with some rough
priorities. Please feel free to send your task
additions, or comment on the relative priorities.
Also, if you would like to work on this project
please let me know roughly how much time you have
available, and what your interests are.
Jeff
______________________________________________
Jeffrey O. Hill         E-mail [email protected]
LANL MS H820            Voice  505 665 1831
Los Alamos NM 87545 USA FAX    505 665 5107
Subject Priority Categories
Define C++ based client side API High CAV4-Client-API
unlimited matrix bounds High CAV4-Process-Entity-Paradigm
unlimited string length High CAV4-Process-Entity-Paradigm
allow several PCAS servers on one machine High Maintenance
Convert old client/serverto use osi routines High Maintenance
EPICS_CA_ADDR_LIST specifies port numbers High Maintenance
if possible, dont allow the server to use the last fd High Maintenance
install PCAS as the IOC server High Maintenance
abstract base class for data description in the server API (backwards compatible) High PCAS
thread safe C++ server library High PCAS
Implement C++ based client side API Normal CAV4-Client-API
write logging (subscribe for name of client that is writing etc) Normal CAV4-Data-Acquisition
application extensible container types (msg passing, cmd compl) Normal CAV4-Process-Entity-Paradigm
application extensible PV attribute set Normal CAV4-Process-Entity-Paradigm
directory serivice resorce location update (detect name space collision) Low CAV4 Directory Service
directory service asynchronous query (implement client) Low CAV4 Directory Service
directory service asynchronous query (implement server) Low CAV4 Directory Service
directory service asynchronous query client side plug in (defne API) Low CAV4 Directory Service
directory service asynchronous query client side plug in (implement) Low CAV4 Directory Service
directory service PV location event subscription Low CAV4 Directory Service
directory service redundancy Low CAV4 Directory Service
directory service server side update (implement client) Low CAV4 Directory Service
directory service server side update (implement server) Low CAV4 Directory Service
directory service server side update plug in (define API) Low CAV4 Directory Service
directory service server side update plug in (implement) Low CAV4 Directory Service
directory service wild card queies Low CAV4 Directory Service
directory service wildcard queries Low CAV4 Directory Service
cancel asynchronous write (put callback) while in progress Low CAV4-Client-API
export process passive to client API Low CAV4-Client-API
2 channels same name => effective 1 channel in client Low CAV4-Compression
combine event subscriptions on same PV in client Low CAV4-Compression
move conversions to client Low CAV4-Compression
protocol compression (level 1) Low CAV4-Compression
protocol compression (level 2) Low CAV4-Compression
application extensable event types Low CAV4-Data-Acquisition
client adj monitor Q length Low CAV4-Data-Acquisition
client adj server's dispatch priority and net QOS Low CAV4-Data-Acquisition
client sets event subscription's min / max rate Low CAV4-Data-Acquisition
client sets server's event queue length Low CAV4-Data-Acquisition
client specified analog event subscription deadband Low CAV4-Data-Acquisition
dynamic evaluation of event trigger criteria in event subscriupton Low CAV4-Data-Acquisition
built in PVs for server diagnostics Low CAV4-Process-Entity-Paradigm
client discovers N dimensional bounds of matrix Low CAV4-Process-Entity-Paradigm
N dimensional matrix addressing Low CAV4-Process-Entity-Paradigm
replace IP broadcast with IP multicast Low CAV4-WAN
strengthened security (kerberos SSH tuinnel) Low CAV4-WAN
Re: CA task list Ralph . Lange
Prev: Positions at Gemini using EPICS Kim Gillies
Next: Re: CA task list Ralph . Lange
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
