1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Slow mv172
To: "Garrett D. Rinehart" <[email protected]>
Cc: [email protected]
Date: Mon, 25 Oct 1999 08:04:26 -1000
Know, I don't know, but we found problems writing (much larger) files
from hkbaja47 's. What mechanism do you use to write these?
We found significant differences between just 'writing' to NFS mounted
disks and writing the files using rcp. Part of the reason of NFS being
slow is TCP/IP stack incompatibility, and part of it is that it is just
plain slow :-). Having said that, it shouldn't really show up for
files as small as you are describing. Other than that, could you have
problems with a full network or with disk access?
Don't know whether this is of any help,
Maren
Garrett D. Rinehart wrote:
> Anyone know why my brand new mv172 takes minutes to write files to
the host where the old mv162 did the same job in
> seconds? Even tiny 150 byte files take upwards of a minute sometimes.
> These are text files BTW. The program writes the data fairly quickly, but then
> it just sits there. Doing repeated "ls" of the file, I can watch the file size
> growing, slowly. The instant it gets to its normal size, the program closes the
> file. So, where's the problem? The ioc reads files from this host just fine.
> Sometimes it writes them just fine too. Much more often than not, however, it
> takes WAY too long. Oh, and this acts the same on two different hosts, on two
> separate networks, and with two different iocs (different CPUs and all).
Slow mv172 Garrett D. Rinehart
Prev: Slow mv172 Garrett D. Rinehart
Next: Daylight Savings Time and the CA Server saa
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
