1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: capfast symbol for transform and ANL motor record?
To: [email protected]
Cc: [email protected]
Date: Thu, 18 Nov 1999 09:44:56 -0700 (MST)
> From [email protected] Wed Nov 17 16:35 MST 1999
> Date: Wed, 17 Nov 1999 13:32:01 -1000 (HST)
> Subject: capfast symbol for transform and ANL motor record?
> X-Sun-Charset: US-ASCII
> Content-Type: text
> Content-Length: 193
> X-Lines: 8
> Can anyone tell me where we can get the latest capfast and ANL motor
> record capfast symbols and edb.def?
> Paul Stomski
> Adaptive Optics Software Engineer
> W.M. Keck Observatory
> Kamuela, Hawaii
Hi Paul,
Did anyone have these symbols and edb.def definitions?
If not, you can make your own by using one of the following methods:
1. Copying the existing estep.sym and modifying it
 with xsymed and copying the part of edb.def that
is for estep.sym and modifying it to work for the ANL motor record.
2.  Using db2capsym to create a new large symbol from the .dbd file
for the record and using dbst -e to create a edb.def part for the record.
With this method you will probably still want to use xsymed to make the
symbol look like you want it to look.
The db2capsym and dbst tools are available from APS, if you follow
the links from releases to extensions and then in item #4, the menu
item "Source for CAPFAST extensions".  There are some README files
and executables for solaris are also available there.
If you decide to use db2capsym and have problems. I can help.
You will also want to put the new symbol into the epics menu
~p3/wcs/lib/menus.new/epicsl.mnu -- or whereever the menu is
at your site.
Hope this helps.
Rozelle
[email protected]
Re: capfast symbol for transform and ANL motor record? Benjamin Franksen
Prev: Re: Channel Archiving Christopher A. Larrieu
Next: RE: Channel Archiving Jeff Hill
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: capfast symbol for transform and ANL motor record? Paul Stomski
Next: Re: capfast symbol for transform and ANL motor record? Benjamin Franksen
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
