1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: empty channel field in medm/dm2k
Date: Sat, 20 Nov 1999 09:04:54 +0900
Yesterday, I checked UDP broadcast messages on the control network.
Analyzing the packet data, I found some programs were searching for the
channel with the name " " (space character). One of source of
these packet was a process running medm2.4.10 on HP-UX workstation.
 In the source code of medm, I found the following code segment
in medm/medm/medmCA.c file.
    if (strlen(name) > (size_t)0) {
        status = ca_build_and_connect(name,TYPENOTCONN,0,
          &(pCh->chid),NULL,medmConnectEventCb,pCh);
    } else {
        status = ca_build_and_connect(" ",TYPENOTCONN,0,
This code segment is a part of the body of "int caAdd(char *name, Record
*pr)" function. I checked several versions of medm (2.3.x, 2.4.x, and
dm2k), and found same code segment in all of them.
If you don't have the channel which has " " as its name , medm
keeps sending CA search while it running.
Easiest workaround is to prepare the channel whose name is " ".
(CA Library and dbLoadXXX accepts it.)
Thanks for listening.
Noboru
Prev: Re: replacing the default CA exception handler Marty Kraimer
Next: Re: empty channel field in medm/dm2k Ken Evans
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
