1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: empty channel field in medm/dm2k
To: "Ben-chin K. Cha" <[email protected]>
Cc: "EPICS-tech-talk" <[email protected]>
Date: Mon, 22 Nov 1999 11:19:33 -0700
> >      Yes, I have noticed.  It was that way when I got it.  I think it
> > is a hack to avoid some kind of error, but I don't know what.  Perhaps
> > it is to force CA to allocate the usual structures instead of properly
> > handling the situation.  I haven't changed it on the grounds that (1)
> > it (up to now) didn't seem to be causing problems and (2) "Never
> > change a working code ...".  It looks like bad coding proctice, and it
> > would be nice to eliminate it, even if it weren't continually calling
> > CA as Noboru says.
> >       Unless someone tells me it is a known trick and has a purpose, I
> > will eliminate it (in the next release).
> I also use this " " to replace the NULL pvname if the user
> mistakenly provided a NULL string for name search to an
> interactive CA client. If I remember it right this will
> avaoid the problem of core dump and accidentally get
> out of the interactive CA client.
I assume that this "core dump" occurs when SEVCHK() is
called and the severity level of the status returned from
CA is higher than a warning. SEVCHK calls abort() in this
situation.
In production code you should check the status from CA
and take appropriate action when the user supplies an
invalid channel name. I assume that appropriate action
in PV wave would be to set a "bad channel" flag in your
code and return bad status back to PV wave applications
when they attempt to read and write to a poorly named
channel.
Jeff
Re: empty channel field in medm/dm2k Ben-chin K. Cha
Prev: EPICS drivers for PLCs? Tony Wilson
Next: Re: EPICS drivers for PLCs? DMW Software
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: empty channel field in medm/dm2k Christopher A. Larrieu
Next: Re: empty channel field in medm/dm2k Ben-chin K. Cha
