Hi all,
can someone tell me the correct way to set all outputs of a mbboDirect
record ?
- I can set fields .B0 - .BF :
dbpf "xvme220:mbboDirect0.B0","1"
DBR_UCHAR: 1 0x1
value = 0 = 0x0
-> dbgf "xvme220:mbboDirect0.B0"
DBR_UCHAR: 1 0x1
value = 0 = 0x0
also I can get the VAL field :
-> dbgf "xvme220:mbboDirect0"
DBR_USHORT: 1 0x1
value = 0 = 0x0
but I want to set all outputs in one operation. I get the following
response when I try the obvious :
-> dbpf "xvme220:mbboDirect0","1"
value = 32833541 = 0x1f50005
-> filename="../recGbl.c" line number=87
Attempt to modify noMod field PV: xvme220:mbboDirect0.VAL error
detected in rout
filename="../dbTest.c" line number=358
Attempt to modify noMod field dbPutField error
The record ref manual (3.13) p173 states "VAL can be changed via dbPuts
at run time when OMSL is supervisory" - (which it is).
The 3.13 record ref manual is inconsistant with the doc on the cebaf ftp
site -
the cebaf doc (probably 3.12) defines VAL as a USHORT, the 3.13 doc
defines VAL as a ENUM,
and my .dbd file also defines VAL as a USHORT.
I am runing 3.13b12
-> dbpr "xvme220:mbboDirect0",4
ACKS: NO_ALARM ACKT: YES ASG: ASP:
0x00000000
B0: 1 B1: 0 B2: 0 B3: 0
B4: 0 B5: 0 B6: 0 B7: 0
B8: 0 B9: 0 BA: 0 BB: 0
BC: 0 BD: 0 BE: 0 BF: 0
BKPT: 0x00 DESC: xvme220 DISA: 0 DISP: 0
DISS: NO_ALARM DISV: 1 DOL:CONSTANT DPVT:
0x00000000
DSET: 0x01bb7080 DTYP: XVME-220 EVNT: 0
FLNK:CONSTANT 0
IVOA: Continue normally IVOV: 0 LALM: 0
LCNT: 0 LSET: 0x01aa0720 MASK: 255
MLIS: 0x000000000000000000000000 MLOK: 0x01ba6d4000000000
MLST: 1 NAME: xvme220:mbboDirect0 NOBT: 8
NSEV: NO_ALARM NSTA: NO_ALARM OMSL: supervisory ORAW: 1
ORBV: 1 OUT:VME_IO #C0 S0 @ PACT: 0 PHAS: 0
PINI: YES PPN: 0x00000000 PPNN: 0x00000000 PRIO: LOW
PROC: 0 PUTF: 0 RBV: 1 RDES:
0x01abd170
RPRO: 0 RSET: 0x01ae9274 RVAL: 1 SCAN:
Passive
SDIS:CONSTANT SEVR: NO_ALARM SHFT: 0
SIML:CONSTANT
SIMM: NO SIMS: NO_ALARM SIOL:CONSTANT SPVT:
0x00000000
STAT: NO_ALARM TIME: 0x0000016339a175f9 TPRO: 0
TSE: 0 TSEL:CONSTANT UDF: 1 VAL: 1
value = 0 = 0x0
here is the .db file :
record(mbboDirect,"xvme220:mbboDirect0") {
field(DESC,"xvme220 ")
field(DTYP,"XVME-220")
field(OUT,"#C0 S0 @")
field(NOBT,"8")
field(PINI,"YES")
what am I doing wrong ??????
Steve
- Re: How to use mbboDirect ? Ralph . Lange
Re: How to use mbboDirect ? Steve Hunt
<1999>
2025
Re: PV's on the www Arne Freyberger
<1999>
2025
