1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: zombie problem at UNIX IOC
To: "Tatiana V. Salikova" <[email protected]>, <[email protected]>
Date: Wed, 8 Dec 1999 09:48:48 -0700
> I have zombie problem at UNIX IOC.
> Pthread is analog of VxWorks task. When IOC receives the request for
> operating with PV,  iocCore spawns the pthreads: "CA event", "CA client".
> Which is completed by "exit()" call or "return ()", this operation
> switches pthread in  zombie state.
On UNIX systems a process is in the "zombie" state when it has exited before
the parent process exits, and the parent has not yet called wait or waitpid
to determine the exit status of the child.
It is difficult to comment further on this because I don't know the LYNXOS
specifics of your port of EPICS iocCore.
The osi based port of iocCore will soon be ready for evaluation on lynxos.
Jeff
> iocCore contains following list of
> pthreads:
> __01.)_____tid=51___name=taskwd____PRI=4.
> __02.)_____tid=54___name=cbLow____PRI=16.
> __03.)_____tid=62___name=cbMedium____PRI=16.
> __04.)_____tid=56___name=cbHigh____PRI=16.
> __05.)_____tid=36___name=dbCaLink____PRI=15.
> __06.)_____tid=78___name=ts_Casync____PRI=16.
> __07.)_____tid=48___name=scanOnce____PRI=16.
> __08.)_____tid=77___name=scan1000____PRI=16.
> __09.)_____tid=50___name=scan500____PRI=15.
> __10.)_____tid=55___name=scan200____PRI=14.
> __11.)_____tid=53___name=scan100____PRI=13.
> __12.)_____tid=49___name=scan50____PRI=12.
> __13.)_____tid=31___name=scan20____PRI=11.
> __14.)_____tid=32___name=scan10____PRI=10.
> __15.)_____tid=67___name=CA TCP____PRI=13.
> __16.)_____tid=66___name=CA UDP____PRI=10.
> __17.)_____tid=37___name=CA online____PRI=10.
> __18.)_____tid=68___name=CA client____PRI=12.
> __19.)_____tid=76___name=CA event____PRI=11.
> __20.)_____tid=75___name=CA client____PRI=12.
> __21.)_____tid=74___name=CA event____PRI=11.
> __22.)_____tid=73___name=CA client____PRI=12.
> __23.)_____tid=72___name=CA event____PRI=11.
> __24.)_____tid=71___name=CA client____PRI=12.
> __25.)_____tid=70___name=CA event____PRI=11.
> __26.)_____tid=69___name=CA client____PRI=12.
> __27.)_____tid=38___name=CA event____PRI=11.
> __28.)_____tid=57___name=CA client____PRI=12.
> __29.)_____tid=64___name=CA event____PRI=11.
> __30.)_____tid=63___name=CA client____PRI=12.
> __31.)_____tid=59___name=CA event____PRI=11.
> __32.)_____tid=65___name=CA client____PRI=12.
> __33.)_____tid=58___name=CA event____PRI=11.
> __34.)_____tid=79___name=CA client____PRI=12.
> __35.)_____tid=80___name=CA event____PRI=11.
> __36.)_____tid=81___name=CA client____PRI=12.
> __37.)_____tid=82___name=CA event____PRI=11.
> __38.)_____tid=83___name=CA client____PRI=12.
> But all threads("CA event","CA client") from iocCore has zombie state.
> Would you help me do this problem?
> Best Regards,
> Tatiana
> Budker Institute of Nuclear Physics
> prospekt Lavrentev  11
> 630090, Novosibirsk, RUSSIA
> fax     +7 3832 342163
> phone   +7 3832 394977
zombie problem at UNIX IOC Tatiana V. Salikova
Prev: Re: Delays in receipt of CA monitors Garrett D. Rinehart
Next: Software Configuration Management document Andrew Johnson
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: zombie problem at UNIX IOC Tatiana V. Salikova
Next: Re: zombie problem at UNIX IOC john sinclair
