1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Delays in receipt of CA monitors
To: "Garrett D. Rinehart" <[email protected]>
Cc: [email protected]
Date: Thu, 09 Dec 1999 07:50:55 -1000
All,
don't know if this helps, but some observations to contribute
from here:
Garrett D. Rinehart wrote:
> Marty wrote:
> > How are the input links configured? CPP CP ?
> Whichever is the default. These databases were in place before those were added.
> The one record in iocB that has an input link from iocA lists it as "PP MS".
I found in one application that not only did I have to set it to CPP
but also had to explicitly put
<name of input record> CPP NMS
into the val(in) field of the hardware input for the input link
to get it to pick up the value.
> > Also look at mbufShow from time to time.
> > netHelp shows all the network show commands supplied with vxWorks.
> number of mbufs: 260
> number of clusters: 7
> number of interface pages: 0
> number of free clusters: 7
> number of times failed to find space: 0
> number of times waited for space: 0
> number of times drained protocols for space: 0
> I did this several times and this one has the lowest number of free mbufs. Most
> of the time it hovers around 190 free.
I found that this sometimes lies, or at least appears to to me :-)
(indicated in my case by the fact that a status string appeared on
a dm screen that this device doesn't have - something was clearly
trampling on something there)
Hope this helps,
Maren Purves, UKIRT
RE: Delays in receipt of CA monitors Garrett D. Rinehart
Prev: RE: Delays in receipt of CA monitors Garrett D. Rinehart
Next: Using GPIB with EPICS Russell Page
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Software Configuration Management document Andrew Johnson
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
