1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: zombie problem at UNIX IOC
To: john sinclair <[email protected]>
Cc: "Tatiana V. Salikova" <[email protected]>, [email protected]
Date: Tue, 14 Dec 1999 19:45:49 +0600 (NSK)
Dear Mr. Sinclair,
I am very thankful to you for your e-mails.
My apologies to you for delay of  answer (11-13 Dec. is holidays in
Russia).
I solved problem of zombie threads by following  way:
"taskSpawn()" executes pthread-detach() call before return().
You can get LynxOS EPICS codes by ftp
sky.inp.nsk.su
user: salikova
passwd: tansalik
epics_LynxOS.x86.tar.gz (It has size 7.9Mb)
As I wrote, Now I test IOC codes.
At N-th reading of PV  "caExample" has next bug.
root:aiExample1 7.000000
FELsparc> caExample root:aiExample1
root:aiExample1 9.000000
root:aiExample1 0.000000
root:aiExample1 1.000000
root:aiExample1 3.000000
CA.Client.Diagnostic..............................................
    Message: "User specified timeout on IO operation expired"
    Severity: "Warning" Context: "ca_pend_io failure"
    Source File: ../caExample.c Line Number: 20
    Message: "The request was ignored because the specified channel is
disconnected"
    Severity: "Error" Context: "ca_get failure"
    Source File: ../caExample.c Line Number: 21
Abort (core dumped)
I shall be grateful if you inform me about your opinion of this bug.
Best Regards,
Tatiana
Budker Institute of Nuclear Physics
prospekt Lavrentev  11
630090, Novosibirsk, RUSSIA
fax     +7 3832 342163
phone   +7 3832 394977
On Fri, 10 Dec 1999, john sinclair wrote:
> On Wed, 8 Dec 1999, Tatiana V. Salikova wrote:
> > Dear Sir/Madam,
> > I have zombie problem at UNIX IOC.
> > Pthread is analog of VxWorks task. When IOC receives the request for
> > operating with PV,  iocCore spawns the pthreads: "CA event", "CA client".
> > Which is completed by "exit()" call or "return ()", this operation
> > switches pthread in  zombie state. iocCore contains following list of
> > pthreads:
> As mentioned by Jeff, zombie threads are threads that have exited
> for which the parent has not called pthread_join. One way to prevent
> this is for the parent to call pthread_detach for each child thread.
> Does this work for all pthread implementations? I don't know.
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 865-576-6362   865-574-1268 (fax)
RE: zombie problem at UNIX IOC Jeff Hill
Re: zombie problem at UNIX IOC john sinclair
Prev: CA monitors... Garrett D. Rinehart
Next: RE: CA monitors... Jeff Hill
Index: 1994  1995  1996  1997  1998  <1999>  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: zombie problem at UNIX IOC john sinclair
Next: RE: zombie problem at UNIX IOC Jeff Hill
