1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: alarm handler question
To: Sue Witherspoon <[email protected]>
Cc: William Lupton <[email protected]>, [email protected]
Date: Wed, 05 Jan 2000 09:55:36 -0600
Maybe we could allow the operator to enable/disable force pvs.
We could add a ForcePV Button to each alarm group or channel line
for which a Force PV is defined ( similar to the Guidance and Related
Process buttons). Pressing this button would bring up the ForcePV Dialog
window which allows the operator to view/change the ForcePV settings.
This dialog could be modified to allow the operator to enable/disable
the ForcePV.  The color of the button could also indicate the enabled/disabled
status.
Janet
Sue Witherspoon wrote:
> > >I'm interested in this issue, for the same sort of scenario occurred
> > >here at Jefferson Lab. It was resolved, probably not elegantly, by
> > >using the cancel mask for the FORCEPV  C----- and leaving the
> > >operators the disable masks to work as expected.
> > So, does FORCEPV "reset" action only restore the flags which were set in
> > the FORCEPV mask? I was under the impression that it restored the default
> > mask (i.e. all flags of the default mask).
> It appears that you are absolutely correct...so now I'm even more
> interested in your proposals!!!!
> ______________________________________________________________
> Sue D. Witherspoon                      TJNAF - CEBA
> [email protected]                        (757) 269-7579
> If my people would Humble, Pray, Seek and Turn....2 Chron. 7:14
Re: alarm handler question William Lupton
Re: alarm handler question Sue Witherspoon
Prev: Re: alarm handler question Sue Witherspoon
Next: EPICS 3.13.2 and vxWorks 5.4 Hammonds, John
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: alarm handler question William Lupton
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
