1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: epics on x86
To: "john sinclair" <[email protected]>, "tech talk" <[email protected]>
Date: Thu, 13 Jan 2000 16:40:38 -0700
John,
This is a symptom off EPICS R3.13's incompatibility with
the new SENS IP kernel from WRS. You can also install the
original IP kernel from WRS. This is frequently the default.
Jeff
> -----Original Message-----
> From: john sinclair [mailto:[email protected]]
> Sent: Wednesday, January 12, 2000 2:12 PM
> To: tech talk
> Subject: epics on x86
> I recently did a fresh install of tornado 1.0.1 (vxw 5.3.1) on solaris
> 5.7. I do not have sens installed. Here is my setup file:
> 05-Jan-00.13:06 TDK-12217-ZC-08 SETUP-1.5
> 05-Jan-00.13:06 100-8827-30     Tornado Cumulative Patch Rev 1: i86
> 05-Jan-00.13:06 100-6808-30     Tornado Object: solaris x i86
> 05-Jan-00.13:15 TDK-12217-ZC-08 SETUP-1.5
> 05-Jan-00.13:15 100-7009-30     VxWorks BSP: pc486
> 10-Jan-00.17:24 Individual Patch for SPR 21254  SETUP-1.5
> 10-Jan-00.17:24 100-10860-30    Tornado 1.0.1: solaris patch SPR 21254
> When the ioc runs iocInit, it does this:
> IocLogClient: EPICS environment variable "EPICS_IOC_LOG_INET" undefined
> iocLogClient: logging disabled
> ###  @(#)EPICS IOC CORE
> ###  @(#)Version R3.13.1..0 $$Date: 1998/11/19 16:18:25 $$
> Starting iocInit
> ioctl SIOCGIFCONF failed: errno = 0x6
> Failed to set time from Unix server
> CAC: SIOCGIFCONF ioctl failed because "errno = 0x6"
> value = 0 = 0x0
> iocInit: All initialization complete
> CA online: A call to "assert (semTake(client_lock, WAIT_FOREVER)==OK)"
> failed in ../access.c at 3089
> Please send a copy of the output from "tt (0x1f89668)" and a copy of this
> message
> to the author or "[email protected]"
> This problem occurred in "@(#)Version R3.13.1..0 $$Date: 1998/11/19
> 16:18:25 $$"
> #seq &snctest
> -> filename="../taskwd.c" line number=175
> task 1f89668 CA online suspended
> tt (0x1f89668) gives the following:
> 154036   _vxTaskEntry   +a  : 3503fc (0, 0, 0, 0, 0, 0, 0, 0, 0, 0)
> 350488   _rsrv_online_notify_task+190: _caSetupBCastAddrList
> (&_beaconAddrList, 10, 13c9)
> 362e55   _caSetupBCastAddrList+bd : _genLocalExcepWFL ([188, 0, 361fd0,
> 2fb, 1f89618])
> 36a526   _genLocalExcepWFL+86 : _epicsAssert (366124, c11, 3660fd, 0)
> 35eade   _epicsAssert   +8e : _taskSuspend ([1f89668, 2fb, 0, 361fd0,
> 1f89598])
> value = 0 = 0x0
> Everything else seems to work. Any ideas?
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 865-576-6362   865-574-1268 (fax)
epics on x86 john sinclair
Prev: Re: VxWorks global variable support extension proposal Carl Lionberger
Next: Re: VxWorks global variable support extension proposal Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: epics on x86 john sinclair
Next: epics on x86 john sinclair
