1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Hardware Collaboration
To: <[email protected]>
Cc: "BiRa" <[email protected]>
Date: Tue, 25 Jan 2000 14:43:32 -0700
Dear All,
Bi Ra Systems is proud to announce a New EPICS supported hardware device called the General Purpose Fieldbus Controller(GPFC)designed by DESY & IHEP. The GPFC is a compact and powerful microcomputer based controller which supports unlimited applications connections via the IndustryPack I/O interface. It was primarily designed as a compact and economical solution for introducing advanced programming and operating environment at the fieldbus level of accelerator control systems. The GPFC main board has two IP slots, so that a wide range of commercially available plug-on IP modules(CAN, Profibus, Ethernet, digital and analog I/O, etc) can be used to configure it to application needs{APPLICATIONS UNLIMITED}. The GPFC's extended(dual board) configuration allows 4 IP modules which provides 28 MB DRAM, 2 MB FLASH.
As a small manufacturing company, Bi Ra Systems is pleased to support EPICS custom hardware for all within the HEP community. A few GPFC will be available for evaluation.
Special thanks to Matthias Clausen(DESY), Serguei Zelepoukine, Piotr Vetrov(IHEP)
Prev: Re: locking and VxWorks global variable device support William Lupton
Next: add_fd_registration in Python/CA. Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
